· Premium Member
2003 Coupe CC has thrown a few P0300 codes in the past couple months. Always during startup. Anyone else experience this?
No, what is the code? Is it the gas cap one? If so then yes mine threw it once.
· Premium Member
No, mine through the evap codes, too - P0300 is random engine misfire, and usually with P030X (individual cylinders). Only happened twice, and then, only at startup after sitting 2 days or so.
I don't know about the Maser specific misfire codes, but I know here in Minnesota, if you've had a BMW, VW, Audi, or any other car with fairly high compression, if the car misfires once on a cold January morning, the check engine light is coming on, and its a random misfire code. Re-start the car a few times, drive it for a bit, and the light turns off. (that doesn't mean there isn't a huge line at all of the above said dealerships a few times per winter)
I think modern knock \ misfire sensors + the tendency towards higher compression motors means this is going to happen more often. It's basically just the first cylinder that fires on start happens to half-fire and then the motor lights.
