On my '09 GT-S with the F1 trans I drove it a couple weeks ago and it did fine but the battery light came on intermittently while cruising at highway speed. This happened a while back and then went away for a long time. This time it stayed on longer. I had my phone with me so turned on the Autel app and it seemed to be charging ok at about 13.6volts but would sometimes dip down below 13.
I've suspected the alternator has been an issue and the previous owner had actually bought a new one but never put it in since it's a bit of a job I'm guessing. So I ordered new belts, intake gaskets and some other odds and ends to tackle that job and other "while I'm in there" things. Still waiting on the parts to show up.
But, after only sitting for a few days I went to drive it and see if I could spot when the voltage dropped. But the car wouldn't start. Then I noticed the F1 pump didn't come on to prime when I opened the door. Threw the trickle charger on thinking the battery might be a bit flat. No love.
The dash and everything lights up but the car was already in neutral (usually puts itself into 1st when parking) and turning the key to start does nothing, no clicks nothing.
Checked the battery with a tester and it didn't seem to be 100% and was somewhere over three years old so got a new battery. Nope, that didn't help one bit.
My next thought was a blown fuse or bad relay. Started looking through the book. It doesn't even show the F1 relay in the diagram?! There is only one fuse that I could find that seems to have anything to do with the F1 system, #54 in the trunk panel. It's fine. The relay off to the left of the trunk fuse panel must be the F1 pump relay though.
When I open the door I do hear the relay click like it's trying to fire up the pump so not sure it's the problem.
I'm going to hook up the Autel again and see if there are any codes but thought I'd post to see if anyone has idea.
