Hi All,
The letter 'E' which I understand means errror with the climate control shows on the dash board of my Gran Sport - I have left it into the dealership and they have neve seen the error and dont know how to fix it! they say it is nothing to worry about and to forget about it! I have no intention of forgetting about it and and told them to sort it - has anyone come across this problem before?
Thanks maserati of minneapolis - that is exactly where the 'E' is showing - I will mention your remarks to the useless dealership the car is with.
Thanks again for the reply.
Phil
The E means the climate control actuator is jammed / faulty. A circa 70 U$ spare which will need 4 to 5 hours labor (ouch) as you need to remove the complete front dash to replace it.
Pot luck. It is not a critical component warning, unless you're freezing into the car (or otherwise).
Thanks Ed - that sounds about right,hense why the dealership did not want to fix it
The car is only 9 months old,so it should be covered under warranty - I hope!
Cheers
Phil
Cheers
Phil
Yes, it should be under warranty. I have that Error a while ago. When that happened, there is no heat in my car. And my dealer changed the actuator under the warranty with no problem.
You've got to yell at your dealer.
pganmol
Related Threads
Maserati Forum
416.4K posts
40.6K members
Since 2003
We’re a forum to discuss the Maserati Coupé, Spyder, GranTurismo, Ghibli, Quattroporte and more!
