1 - 20 of 48 Posts
I've only had this car for a week or so, but every 15 starts or so, I get a big billow of smoke (bluish maybe) from the exhaust. Not always the first start of the day. Looks like oil smoke. Is this normal-- any suggestions or comments?
My dealer told me about a customer who started using his car regularly on the track and then complained it was blowing some smoke at start up.
When Maserati were asked they said this was normal behaviour and that the car is designed to clear oil residue in this way after HARD use.
Can anyone confirm?
Same thing happens with mine from time to time on start-up, I have brought it up to the dealer and apparently it is normal for these cars to do it. In fact as I was asking the question a brand new coupe started infront of us and did the exact same thing!
Thanks for your messages -- I was about to chew out the dealer who sold me the car for not having checked it out!! Happy motoring. I've got six weeks or so before she goes into storage for winter.
2004 Coupe here. Same thing since I got it with 300 miles on it (4,800 now).
I feel a little embarassed when I start the car in front of people and a plume of blue smoke comes out and hangs around the back of the car.
I've never noticed it, but it seems normal I guess. After driving my car hard, I drive it around for about 2 miles at lower rpm's. I also drive my car daily so maybe that has something to do with it.
Well...with other cars (mind you I havnt driving my Maserati "full time" yet..) white/blue -ish smoke from the exhaust when you start up or accelerate means the oil ring on either one, or more, of your pistons is worn, and oil is traveling and mixing wiith the gas/air mixture and being combust...ed.
PS. Sorry for the old thread posting... it's just that nobody mentioned this.
Just another its normal don't worry about it post.
Blue smoke is oil, white smoke can be either coolant or rich air\fuel mixture. Coolant will have a very sweet smell with it, almost like burning brown sugar. Burning clutch \ brake fluid is very acrid. Like rotting fish.
I suspect it has to do with the Aluminum block\head and piston makeup expanding at different rates. When the car is shut off warm vs cold there is not as much oil residue left above the pistons because of the thermal expansion vs. a thicker coating when left after driving for a short period and the engine not coming up to full temperature, combined with high oil pressure. I'm fairly sure this is also why the synthetic oil is more important, due to its thermal stability..
The car shouldn't burn enough to worry about it in between changes, since these have a pretty generous sump with plenty of reserve.
Compare this to any Porsche turbo, which is expected to burn a quart every 1000 miles during break-in, and 1qt per 1500-3k after that I think?
- Mark
right you are. with the flat six and dry sump the only place for the oil to settle is in the bottom of the cylinders and you always get some smoke at startup.
the owner's manual for the Targa says add a quart every 600 miles - that's about every 2 fillups.
they also mark their territory almost as badly as a Brit motorcycle.
Small Quantity of Blue Smoke on Startup
Is caused because forged pistons need more tolerance in the cylinder walls than cast pistons due to the amount of expansion once the pistons are at running temperature. Until the piston expands, it's get's warm enough in the combustion chamber, it's completely normal for it to blow out just a tad of blue smoke. Now my custom built 327 Chevy even does this because of the forged pistons and the greater tolerance needed because of this... It's normal.... In fact the F1 cars all have forged and glass beaded pistons and they smoke exactly the same on startup......
Anyone with a Harley should be familiar with dry sump oil burning during start up. Same pricipal on the Maser. The pump loses pressure while sitting and the oil leaks back into the cyls. Totally normal and adds to the cars character.
1 - 20 of 48 Posts
