Thought so,..Just saved me 400 bucks. Thank you.I don't think they make a difference at all in pedal feel..I have installed a ton them...J
I've driven many cars, and quite a few on the track, and kept a few cars for a long time and brake line failure has never been an issue... as in I have never had to replace a brake line on any of my cars, including my 100,000 mile Miata which had seen some semi-hard usage. As for Maserati, of all the failures on the GT line, brake line failure has not been an issue that's been experienced by owners here.So longevity is not a benefit with ss brake lines ? Or, Maserati regular lines are not really prone to premature failure, so it’s not an issue ?
Much cheaper over here! I fitted them to my Coupe because the old lines were going, and they felt much better. But the old lines were failing.....Thought so,..Just saved me 400 bucks. Thank you.
Many Porsche forum members switched to all steel for both brake lines and clutch hoses since there was a sufficient number of them failing at 30-40 K miles to make a lot of people paranoid and go on a buying spree for the ss versions . That included my car ( only the clutch line failed around 45 K miles, but the brake ones have been fine and still are at 115 K miles.. and I tracked that car quite a bit also ). The spot where they failed was very consistent among all the ones reported ; right at the junctions of metal and rubber. The rubber eventually developed tears / slits at those points.I've driven many cars, and quite a few on the track, and kept a few cars for a long time and brake line failure has never been an issue... as in I have never had to replace a brake line on any of my cars, including my 100,000 mile Miata which had seen some semi-hard usage. As for Maserati, of all the failures on the GT line, brake line failure has not been an issue that's been experienced by owners here.
Definitely not worth it for $400 but if they’re old and you DIY it can be done for no more than $150.Thought so,..Just saved me 400 bucks. Thank you.
And thus, the weight savings make the car quicker ..so there IS a performance benefit !🙃They make your wallet lighter
The net gain in speed and performance would be equivalent to putting a vinyl TURBO sticker on your car and just 'feeling' it go faster!Definitely not worth it for $400 but if they’re old and you DIY it can be done for no more than $150.
I changed them on my GS due to age and didn’t notice any improvement - no track use though
No no... a turbo on an Italian V8? It has to be naturally aspirated.The net gain in speed and performance would be equivalent to putting a vinyl TURBO sticker on your car and just 'feeling' it go faster!
I always thought that TRD was just a short version of TuRD....and for that reason I am out!No no... a turbo on an Italian V8? It has to be naturally aspirated.
Go with the TRD or Mopar sticker instead.
