Do I sell my Maserati?
1306 Views 21 Replies 9 Participants Last post by  Fineito
I have a 2012 Maserati Granturismo_c it was my late dads car and he loved it and I love it. It’s starting to give us problems like evap leak and sticky buttons and noises coming from the car. I mean to me it seems like it needs a one time fixing because most of its parts have been on that car since 2012. I want to keep it but my mom’s pressuring me to sell it, I feel like if I put the money into it right now it’ll be fixed and it’ll just be maintenance from then on. My mom says it’s gonna keep giving problems and be bad for us, and it’s got outdated technology. I don’t know what to do. Am I right or my mom? Should I keep it?
1 - 20 of 22 Posts
they aren't very problematic cars, might just need some general maintenance. Any mechanic can work on it.
Reactions: 1
My evap issue was just some debris. Dealer cleaned it out and good to go. Sticky buttons are what they are. PITA to fix. Will it be a daily driver?
Reactions: 1
Nah I’m looking to get another car to daily and keep this as a weekend car, however I just got off the phone and I need brake kits the mechanic said and tires and he thinks it’s gonna be another thing or too
Brakes are just Brembos so don’t overpay.
Reactions: 1
If this is the case I would just keep it however, your financial situation will suggest what the best/smartest thing might be to do.
Reactions: 1
If you don’t fix it you won’t get much for it.
agree that it depends on your financial situation. These cars are not problematic, but when something goes wrong it cost some bucks. Brakes and Tires are just normal wear and tear and as mentioned you can get a set of 4 brake pads for probably 300 bucks from ECB or equal. some people do their own brake jobs if mechanic oriented. I changed them once on a disk brake car and it's surprisingly simple if you have the right tools.
This is the ultimate weekend car and if you can put some money into it to fix things and like to tinker you can have a weekend ride and it will also be a part of your dad to keep with you.
Reactions: 1
The mechanic i took my car to says i need 2 new front disks and a brake pad set and which will total too $2,632 including labor, He got his quote from the dealer im pretty sure, should i go with it or try to get some cheaper brake disks?
  • Wow
Reactions: 1
So if i do wanna sell it, i should fix it then sell it? or try selling without fixing?
Why not give these a try? I hear FD is a solid option.
They also have 2 options for pads:
Maybe about $1400 in parts. They are charging you $1200-$1300 in labor which seems excessive in my opinion unless they are using more expensive dealer sourced parts.
See if he will do it with your parts and you just pay the labor rate.
Also please verify these parts fit on your car.
See less See more
Reactions: 1
A brake job on this car for one axle takes max. 1 hour, same in the rear. So i dont know how much they charge for labor.. but honestly that does not sound right.
Reactions: 1
Brakes and rotors are really easy to replace. Sticky buttons are somewhat troubling depending upon how often they are used. IMHO, Masi should have made them either aluminum or hard plastic to avoid the black rubber getting messy after a certain amount of time. Italian design but an afterthought on the material for heavily-used items in the car.
Reactions: 1
Yeah i called him and he said he talked to the dealership
Font Rectangle Parallel Screenshot Number
See less See more
Alright thanks ill have a talk with him but a family friend said his best friend is a mechanic and he wont charge much for labor so i might just go to him after he gives me rest of the estimate
See less See more
I just received a Chicagoland Mas dealer quote of $1,500 for rear brakes on a 2012 QP5 Sport GTS. My understanding is that such amount includes new rotors and pads - i.e., an "all in" cost, before any dealer discount coupons.
Reactions: 1
That quote is for labor and parts , including rotors ?! From a Maserati dealer no less ? Wow, I would not expect that low of a price from a dealer, no matter where they may be located. I'd double check and get every bit of detail of that quote in writing.
Reactions: 1
Hello DSGT, I stand by my response. I am quoting the recommended work..."RBR rear brake job, replace pads, replace rotors, free up caliper slides." $1,400 before any coupons. Now, on my valve cover gasket job, an amount was quoted about twice the range I was expecting based on ML search findings. These are estimates, of course, and not based on an actual invoice.
(y) (y) . That‘s great, glad to hear it ! My friend who has a an MC got a quote for $ 6, 000 + ( front and rear ) rotors and pads job. Then again, those we’re from Beverly Hills and Newport Beach Ferrari - Maserati dealers, so perhaps not surprising ..
The only experience I have on these matters is that of a consumer. I read car material, chat forums, and have my own experience over the years to make me a somewhat educated consumer. I have heard from several service firms that finding good techs is difficult these days. My sense is also that good service vendors have a lot of work in the queue. Because of current circumstances, my sense is that sometimes there is a certain amount of "premium" pricing going on in the industry; one can put forth an above-market quote, and if gotten, great! If not, plenty of other work in the queue. Please understand, my intuition only.
1 - 20 of 22 Posts
