High-beam: Spyder, Coupes & GS
as of 09/06/2006
Headlights / High-beam: The high-beam bulb used on our vehicles is the style: "H1-55W". The original bulb provides a yellow cast and is unsatisfactory especially compared to the High Intensity low-beam lights. I replaced the bulbs with new from Sylvania: H1 ST Silverstar which gave me a noticeable improvement. (The glass-bulb is blue, but generate a much brighter and whiter light)
Typical cost of original bulb at AutoZone and the likes are ~ $6, the Silverstar, found at Wal-Mart, was $18.72 + tax.
The job of replacement. Either buy the bulbs and let your dealer install them or:
Remove: Front wheels, Inner liner and Plastic cover over the H1-bulb. To open the cover turn counter-clockwise. Prepare a short wooden dowel for leverage (6x28x~50mm) as to help open cover. (To be inserted in the bottom of the cover) This is needed mostly on the driver side, as obstruction is significant and access difficult.
Careful remove (pull back) the wires before removing the bulb. Again on driver side this is difficult, and I ended up removing the bulb with wires, but risk is high for braking the bulb which is under pressure.
Prepare a small wooden stick or small size diameter rigid tube L~300mm for holding the new bulb(s), keep in place by a bit of tape, and re-insert the new bulb. DON'T TOUCH THE GLASS!.
The job is not at all easy, but for sure worth the time and cost!
Enjoy! Kai
