21 - 34 of 34 Posts
O
Thanks for the info. Is there a recommended mileage interval for changing the differential oil? I didn't see one in the owner's manual.
You could also use amsoil oil packs works like a charm in that hard to reach area. No mess.
Changing the Transmission Fluid & Filter is an option as well.
Thank you Jason. I have noted the diff change in my service sheet!! Like you said, it has a fill and drain plug.
O
Looks interesting. I'm assuming you used a funnel to add the lube to the differential.
The oil filter in The transmission is not mentioned in The Maserati workshop manual what I found. Is anyone having a detailed instruction how The replace The filter?
Go to youtube and search ZF 6HP 26 servicing...The procedure for BMWs etc...is pretty much the same...Note some makes you a plastic pan and not metal like a Maserati.. Jason
USE THE PART NUMBER AND ORDER THE CORRECT ITEM. If the transmission is a ZF 6HP26.
Don't buy the all in one filter and oil pan....Keep the metal pan and buy just the filter.
If you wanted to tune up the transmission follow the link below.
21 - 34 of 34 Posts
