1 - 2 of 2 Posts
OK, here's a diagram. Which one is the purge valve? I was told that this was getting stuck and causing my coupe to REV and shut down every now and then. Thanks for the help.
its number 28 its actually on the driver side of the engine compartment, but I highly doubt this would cause stalling check your mas air flow sensor to see if it is properly installed I seen loose boots cause stall.
1 - 2 of 2 Posts
