???Is there any way to set the Skyhook suspension to start up on "sport" mode? I find that I'm turning it on every time I get behind the wheel. Thanks - Bill
The Skyhook reverts to normal mode when I shut down my 03 Coupe. I'm not surprised that Mase fixed this in the GS, but from the replies it looks like it stays lit for 02 Coupe owners.???
With the SPORT mode ON (you see the amber SPORT lightning on the dash) the Skyhook is also ON on SPORT (stiffened). It stays ON as default until you press again the SPORT button (note: switching ignition off does not revert to normal mode in the GS, but IT DOES on the Coupe).
Simple.
being able to hack the magnetti merelli software would be the start of that...then creating a GUI that translates it into what lines of code do what...and while you are in there see if you can find a way to emulate an SDS-3 so we can run our own Kiss Point calibrations and TCU resetsThe Skyhook reverts to normal mode when I shut down my 03 Coupe. I'm not surprised that Mase fixed this in the GS, but from the replies it looks like it stays lit for 02 Coupe owners.Wonder if there's an ECU setting for this and, if so, how I get to it....
It was a lot easier to get into the ECU settings in my old Audi TT...you could get the GUI's for that....being able to hack the magnetti merelli software would be the start of that...then creating a GUI that translates it into what lines of code do what...and while you are in there see if you can find a way to emulate an SDS-3 so we can run our own Kiss Point calibrations and TCU resets
