1 - 1 of 1 Posts
Sponsor
After working hard to get your valuable Maserati shiny and clean you're going to want to protect it from dust and other debris without leaving your pockets empty. Covercraft, the world's largest manufacturer of custom car covers has a perfect solution for you – Block-IT 200 Car Cover! It offers great basic protection, and excellent value for indoor storage and mild outdoor use. It is crafted using three-layer polypropylene to provide resistance to dust, mold, UV rays and moisture. This car cover is also lightweight, which makes it easy to use and store when not in use. We've prepared a new video review to tell you more about its specifications and benefits.
Covercraft® Block-It™ 200 Gray Custom Car Cover
Features:
- Uses 3-layer polypropylene construction for moisture and dust resistance, and the fibers are treated for extra UV resistance
- Middle layer is a breathable film with microscopic size holes that are small enough to block dust pass-through while effectively allowing moisture and heat to escape from underneath
- Elastic edging surrounds all sides to create a snug fit that is just right and not too tight
- Reinforced, non-scratch grommets include a protective flap on the backside and can be used with a tie-down rope
- 2-year warranty - warranty coverage protects against defects in material and workmanship, as well as the fabric becoming unserviceable during normal use
- Great for everyday use or long-term storage.
Covercraft™ | Custom Car Covers, Seat Covers, Sun Shades - CARiD.com
Protect your Maserati while it's in storage with Covercraft Block-IT 200 Car Cover!​
1 - 1 of 1 Posts
