Has anyone bypassed their standard airbox with a cold air intake / conical filter? Doesn't look like there's much room past the Mass Airflow Sensor. Maybe removing the airbox and sticking it into that space?
I think there is no better place other than the original. I put K&N conical filter(with end cap) on my car. I took the plastic airbox out(hoping that the car breath easier) and sticking the filter in the original place and also have to modify the filter inlet a bit to fit. My filter is a bit larger than BMC (maybe 20% more surface area).BeeYouZeeZee said:Has anyone bypassed their standard airbox with a cold air intake / conical filter? Doesn't look like there's much room past the Mass Airflow Sensor. Maybe removing the airbox and sticking it into that space?
Did you notice an improvement? Did the intake get loud under power?pganmol said:I think there is no better place other than the original. I put K&N conical filter(with end cap) on my car. I took the plastic airbox out(hoping that the car breath easier) and sticking the filter in the original place and also have to modify the filter inlet a bit to fit. My filter is a bit larger than BMC (maybe 20% more surface area).
How about your viper, did you feel any improvement when you change air filter?BeeYouZeeZee said:Did you notice an improvement? Did the intake get loud under power?
Thanks for the advice. I think I have insulate tape somewhere in the houseFormulaDynamics said:One thing you can do ( especially for people in warm climate areas ) is to simply wrap your existing intake / ducting with a material which blocks heat. The Maserati engine suffers from significant "heat soak" which robs you of real horsepower when the engine temperatures heat up the air and fuel before combustion.
