1 - 3 of 3 Posts
Someone to help me solve a problem I have with the Gearbox of my Maserati Spyder 4.2.
Hello friends, we changed the cluth set in the gearbox of the Maserati Spyder 4.2 year 2004, this set of cluth was installed completely new, but once it was armed the whole engine does not start and the scaner indicates that there is a code Error No P0715. Who can explain what is happening and how can I solve it !!
Sounds like you have something installed incorrectly or a defective part with the clutch position sensor.. You can solve it by taking it all back apart again and inspecting your work...Jason
Performance Specialist
This Error is typically related to Gearbox RPM Signal quality. Make sure there isn't any damage to this wire or harness. It could be the clutch position sensor as well, the errors for the transmission aren't really 100% reliable but this should help point you in the right direction in any case.
If this is a CC or F1 car, be sure to do all the needed clutch calibrations with the diagnostic tool, good luck!
1 - 3 of 3 Posts
