Many may find this to be a silly question, but I've been driving manuals my whole life and have never had a clutch go out. I am the proud owner of a 2005 CC Coupe w/ 5600 miles and wanted to know how I will be able to tell when the clutch begins slipping?
When I shift I am hitting the paddle with my foot on the gas, then lightly raising and reengaging when the car moves into the next gear. I notice that occasionally I see a slight increase in RPMs as the shift takes place (even after raising my foot off the gas) and the shift occurs smoothly and without odor :)
Is the above normal? What should I be watching out for? I have searched endlessly and find plenty of threads on slippage, but outside of smell, no other documented "symptoms". Thanks much, loving the car so far!
That's normal. The CC does not rev-match on its own during upshifts.
If the clutch was slipping, you'd notice it while accelerating through 3rd-6th gear (not the slip that happens while shifting).
Don't worry, my friend, when your clutch starts slipping you'll know! It's very easy to notice when taking off uphill, the clutch will screech a bit and then the car will go. Even a slight slope will do it.
I bought my car with 14,000 miles and after a few hundred miles the clutch started slipping. It ended up needing only a software upgrade and it's just fine now.:)
If it's slipping....
You will notice the rpm fluctuating while driving straight down the road at a level speed without changing the throttle position, you will hear it, you will feel it as well.
