So after modifying the exhaust my cats broke up and are now rattling, should I just replace them or go for new headers and cat deletes please share opinions.
I heard someone talking about me...This guy explains the different headers
@OP- what isnt mentioned is that doing this necessitates the relocation of the lambda's wiring loom to the back of the engine bay as per the early EU3 compliant cars...One of the guys here gutted the primary cat and installed a new Larini sport cat secondary cats which have the plugs for the O2 sensors. That's possibly the easiest way but I don't know how legal it is in USA but given that you're still running cats it should be fine.
It isn't so bad, the primary sensors don't need to be moved and the secondaries can be coded out, defeated, or you can run extensions. The oil line is fine with a bit of heat sleeve. But yes, you're right, definitely worth being aware of!@OP- what isnt mentioned is that doing this necessitates the relocation of the lambda's wiring loom to the back of the engine bay as per the early EU3 compliant cars...
Swapping between EU3-4 presents issues with heat shield design as the return oil pipe requires heat shield protection due to proximity of the earlier manifolds...
Just FYI....
