If you can perform the adjustment yourself, that's great! I hope this will help you.
Instruction is applicable on cars that featue the gearbox controls p/n 198245 (Spyder GT) and p/n 198242 (Coupe GT) (From assembly number 10256) onwards.
- Hold firmly the gearshift lever in neutral by mean of tool p/n 900026260
- Check that the axis-to-axis dimension between the ball joints of lever corresponds to 76+/-0.5mm
Adjusting the gearshift wire
- Disconnect the cable from bracket (A) and from the ball joint of rocker (B)
- Connect the head of the cable to the bracket
- Open the linking block (C) and connect the plastic (D) end to the ball joint of the rocker
- Let the internal spring compensatee the freeplay of the cable then close the linking block
Adjusting the gears selection
- Disconnect the cable from backet (A) and from the ball join of rocker (B)
- Open the linking block and connect (C) the plastic end (D) to the ball joint of the rocker
- Hang a weight heavy 3.5-4.0 Kg about to the ball joint of the rocker and let it droop from the spacer bar (A) of the exhause, with a wire so that the freeplay of the system will be compensated. Then close the linking block
