1 - 2 of 2 Posts
Hi,
I've got a 14 Ghibli SQ4. Doing both front and rear brakes this weekend myself.
Does anyone have the torque specs for the 2 the bolts on the front & then rear caliper? Also the bolt that goes through the 3 piston on top, for the fronts.
If interested, my TLDR:
Brake quote from the dealer is $3k. I was able to find rotors at R1 Concepts for $300 and got EBC Yellowstuff brake pads for about $270, which includes hardware. I consider both of these to be comparable OEM, but Formula Dynamics has Kevlar pads at $600 if you want to spend more.
Thanks.
Discussion Starter #2
Hi,
Does anyone have the torque specs for the 2 the bolts on the front & then rear caliper? Also the bolt that goes through the 3 piston on top, for the fronts.https://discord.software/ fetLife itunes
Thanks.
my issue got solved!!
1 - 2 of 2 Posts
