1 - 3 of 3 Posts
Hi guys,
2 unrelated questions:
1) I need a fuel pump. Prices seem to run $250 for used. Any ideas as to other makes' pumps which might work here?
2) The replacement UFI oil filters from MIE are expensive. I understand there is interchageability between mid-90s V6 Alfas. Any ideas as to cheap interchanges?
Many thanks!
I do some business with a UFI distributor (mostly hydraulic filters) but if you have the UFI code I could probably find out what a more realistic price should be. Furthermore; I have another filter supplier (MP Filtri of Italy) who can cross reference just about any filter part number and offer their own version. If you contact them in your own country, wherever that may be, they will probably be able to give you a part number and your local stockist.
Might be worth a go.
As for the fuel pump, in the owners manual it looks like quite a common electrical diaphragm / plunger type like a Bendix / Facet / Purolator style
http://www.eurospares.co.uk/userImages/132/Large/132_024.gif
Assuming I have selected the right model. If you google it you should find a replacement for a better cost from a specialist. If you have the old one see if there is any indication as to flow-rate, the output hose connection diameter, voltage, positive/negative earth, pump body diameter and length, that type of thing.
Hi guys,
Many thanks!
Here's a reference chart i have gathered:
oil filter
WIX Part Number : 51335
Fram Part Number: PH2870A (long, not for 2.5l,2.8l) or PH3614 (short) or PH3589
NAPA Gold Part Number: 1342
Lexus model: es300
AUDI: 80 1.3,1.6,2.0 (EP,PP,RN 81-91)
air filter
Fram Part Number: CA4415
Mahle: LX252
Purolator: A34762
WIX Part Number: 46136
Motonet: 16-9043
BMW 323i E21 --82
This filter is 13.5 in. long, 8.1 in. wide and 1 in. thick.
fuel filter
Fram Part Number: G3713
SAAB 99 2.0 Turbo Berline 146cv
FIAT Coupe 2.0i 16V Turbo
Lancia Crom 2.0ie Turbo
Lancia Tempra 2.0ie
FIAT Ducato 14 2.0i
1 - 3 of 3 Posts
