1 - 20 of 40 Posts
Looking for input on a battery maintainer/tender and whether or not the OEM one is really necessary or if a generic one will work fine.
I see the OEM one on Amazon for $169 but generic ones for much cheaper.
If a non-OEM is ok, does anyone have any suggestions? Thanks in advance.
Deltran works just fine. Nothing special about theses batteries unless you installed LiO4.
I just went to a local auto parts place and got a CTEK for my car. The battery connections were already installed from the previous owner.
I had actually gone in to the dealer here to inquire about one and he said just get a CTEK as it’s much cheaper than what he could get me. Said that it’s the same thing just without the trident on it and half the price.
CTEK is what Ferrari, Maserati and other exotic car marques use. The OEM Maserati one is a rebadged CTEK. I use a regular CTEK and it works perfectly.
ALL CTEKs. Good enough for me. Here's the one I use which is a higher end model than most of the branded versions above:
Get it with the cigarette lighter adapter and you can just plug it into the socket on the left side in your trunk:
I use the Del-Tran Battery Tender on all my cars and motorcycles and never had a problem. I've even been able to save a few "dead" batteries after leaving it on for 3 days.
Discussion Starter #7
thanks! I saw a few options for ctek so wasn't sure which one was best so I appreciate the suggestion!
Mine came with the factory CTEK system but as I have a few extra Battery Tenders I didn't even bother to take it out of the box.
Sav-A-Battery Charger/Maintainer on Amazon. These are the ONLY units I trust to leave on the car 24/7. Great extra features also.
I also used Sav-A-Battery for years but they eventually craped out. The last one burned out and drew the batty down to 5v before I discovered it. I replaced it with a Suaoki 7A (Amazon?) and couldn’t be more pleased. It uses a series of low amperage programs to test and condition the battery. The initial test and conditioning program ran 36 hours.
131394
Discussion Starter #12
I appreciate all the responses, thank you! I purchased a CTEK unit for my GT. Except I don't have my GT yet lol. I just closed an out of state purchase and it should be delivered around 5/29. It's gonna be a long 10 days....lol
Congrats!! Yes, it'll be the longest 10 days ever!
Are you keeping the Ghibli as well? I hope so, they are beautiful cars!
Discussion Starter #14
Thanks! Definitely keeping the Ghibli, I love that car and it's my daily. Will post pics of the Ghibli and MC together once I can!
Be careful to check the outlet in the trunk as on my QP6 the connection is only live when the ignition is on s no use for charging.
I use the Ctek lead with the spade connectors which can be permanently wired to the battery. The leads can easily be fed into the boot and it includes a battery condition indicator
The cigarette plug in the trunk of the Granturismo is always live, so can be used with a tender.
Love the CTEK battery tester/maintainer. Just remember to check your battery chemistry. I switched to a AGM battery and had to change the mode of the CTEK to properly maintain it so keep your manual. Not sure if a Lithium battery needs a totally different unit.
Cigarette lighters are never a good primary option. Reverse flow charging has its own issues. Save that for emergencies only. Anything sold on Amazon is prone to being a cheap chinese knockoff. Bezos has ripped off the public in ways Walmart could only dream of.
Any ideas what to do if your car is in a shared garage with no outlet access?
Buy a really long extension cord.
1 - 20 of 40 Posts
