BATTERY COMPONENT SELF-LEARNING IN THE EVENT OF BATTERY DISCONNECTION
1. After connecting the battery negative terminal, the following self-learning operations must be performed to ensure that certain connected devices acknowledge the system again:
2. "EPB FAILURE" AND "PARKING BRAKE ENGAGED" WARNING LIGHTS Each time the battery is reconnected, the “EPB FAILURE” and “PARKING BRAKE ENGAGED” warning lights flash for about 10 seconds and then go off. This is normal and not indicative of a failure.
3. MOTOR DRIVEN THROTTLE SELF-LEARNING Turn the ignition switch to on (KEY ON) and wait at least 15 seconds.
4. After performing the self-learning cycle for the “throttle position”, you must perform the same cycle also for the timing variators (VVT). To do this, start the engine and let it idle for about 20 seconds. 5. CENTRAL DOOR LOCKING LOCK and UNLOCK the doors using the remote control
6. NIT (IT node) and CLOCK Turn the ignition switch to ON (KEY ON)
7. Turn on the IT Node, reset the correct time and date since the IT node looses this information every time the battery is disconnected.
8. FRONT SEATS Following any power cut-out (e.g. after using the battery master switch or if the battery has run flat), check the seats to ensure that they are operating properly when the power supply is available. Perform the following procedures on both seats in the event of a malfunction.
9. When the ignition key is at STOP and the door next to the seat concerned is closed, open the door and start the following procedure within 5 seconds, then complete it within 10 seconds.
10. forward - STOP backward - STOP forward - STOP backward - STOP tilt the seatback fully forward and wait until the seat performs two complete travels (forward and backward). Put the backrest in the normal position. If you need to disconnect the battery, wait at least 30 seconds from the last seat movement. If you disconnect the battery before, you will have to run the initialisation procedure.
I think the following is just info for technicians
11. TGK VALVE STROKE SELF-LEARNING Every time the battery is connected, the acquisition procedure relating to both the water valves is started.
12. After connecting the battery, turn the key to ON and wait at least 15 seconds before starting the engine.
13. The phases for a correct self-learning of the strokes are the the following:
14. complete valve opening (max. 6 seconds)
15. memorisation of the opening position of both valves (950 on the average)
16. complete valve closing (max. 6 seconds)
17. memorisation of the closing position of both valves (50 on the average)
18. memorisation of both valves' stroke (Stroke=Opening-Closing, 900 on the average)
19. stroke analysis if even only one of the 2 strokes is below 500, both strokes are assigned a recovery value of 800 and the procedure is repeated upon the next network wake-up or when the key is turned to ON if both strokes are above 500, the strokes correspond to those calculated and the procedure will not be repeated upon the next network wake-up or when the key is turned to ON
