1 - 20 of 85 Posts
I own a 2014 Gran Turismo Sport. I love the care but I'm tired of the poor microphone and having to use Bovee for Bluetooth. I'm going to replace the entire system with something more state of the art.
Does anyone have advice on the best system to use which fits in the space? I'm in Westlake Village, CA. Any vendor recommendations would also be appreciated.
Thanks in advance,
Robert
Radio upgrade
As my GT in sleeping through the winter. I am in the process of making my own radio upgrade. I am installing a 9" android touch screen system to replace both the radio and original display.
I have been looking for upgrades in the net and you tube but not found any real good installs. all have cutting or modifying or used the original display. But the quality of the displays today are much better than the original so I am getting the center panel redesigned to fit the 9" display.
My plan is to make a kit that everybody can order. I will move the original radio system to the trunk in order not to get error codes and alarms in your dash display. The radio will be positioned in the battery compartment and the display in the right wheel cover under the lid.
Everything will come as a plug and play without having to cut or solder any wires. ( have access to all the tools to make the connectors at work)
So far I have been sourcing all the correct connectors to make custom harness.
I have 3D scanned the original panel and is designing a new panel that can be 3D printed.
I am also investigating the CAN controls regarding the Steering wheel controls in order to get them working.
keep you posted on the progress:smile2:
Franz,
I am planning on tackling the Android headunit and audio upgrade once things warm up a little bit here in VA. I read an entire thread on here from a guy that did it and it was fantastic work and made a WORLD of difference to achieving a more contemporary aesthetic for our car. I have my shopping list all ready to go and am excited to get started. I have some decent experience with system installs from my younger years so I am really hoping some of the old knowledge is still in my head somewhere. I think, wiring drama aside, fabricating the double din surround piece and making it look factory will be the most challenging part.
Any wiring harness design that will make the NIT relocation and new Android unit easier to install to a PROPER amp in place of the bose would be truly wonderful. And of course, a clean looking Double Din faceplate.....My credit card is ready when you are, brother!
Keep us posted on your progress and lots of pics (ESPECIALLY THE DASH!!)
~Chaz
Wow...that sounds like an ambitious plan! Keep us posted on your progress!!
2013 Maserati GranTurismo MC
I am in the process of closing a deal on a 2013 GT MC and this is one of the first upgrades on my list. I have actually been looking for a plug-and-play type of harness for these cars but nothing so far. If you are making a harness for radio upgrade, my credit card would also be ready when you are...
As for the actual upgrade, I am leaning towards leaving the original display in there as is and only replacing the radio with a single-DIN system. Specifically, the Alpine Halo9 system. My list would probably be something along the line of:
1. Head Unit: Alpine iLX-F309 ($899)
2. Front and Rear Cameras: Alpine HCE-C2600FD & HCE-C2600RD ($299 each)
3. Video Selection module: Alpine KCX-C250MC ($199)
4. Steering Wheel Controls: If the Alpine HU isn't setup for it
5. Audio upgrades: Will decide once I actually have the car in my possession :)
Even with just the basics, I am at about $1,700. I can see the parts total getting up to $2-3K easily depending on what else I decide to upgrade. I'd be doing the upgrade myself so labor cost is not involved.
Anywho...if you guys want to see how that Alpine unit looks, below are some videos:
(Also attached are pictures from Alpine's Facebook page. They are from the 2016 GTS vert done by Fantazy Motorsports)
(Audiofile-Incar based in UK)
https://youtu.be/VH_45LE3oVQ
(Fantazy Motorsports based in CA, USA)
https://youtu.be/oPhHaGFNzdo
https://youtu.be/ATBScYMFSpw
Seems pretty invasive to leave the stock screen in place. What about the Navi Plus setup? Seems like a better use of the in place screen. Unless there are other benefits that come with this unit that I'm not picking up on?
If my understanding is correct, the Naviplus install uses the OEM screen for display so it would be limited by the size and resolution of the stock screen. In other words, 7" of usable screen and resolution is not HD. I can't imagine putting that much time and money into an upgrade and still ending up with a small, non-HD screen.
Anyways, despite the invasive install, I would be okay leaving the OEM screen as is because: 1) avoid having to relocate it somewhere else and 2) keep the car from freaking out. From the look of the Alpine install, I doubt the factory screen would be very visible once the aftermarket screen is installed. The Alpine unit can be adjusted for height/angle so good chance you can get it close enough to cover up the original screen. This method would keep involved wiring to a minimum and I assume a simple harness would be enough to allow the Alpine to tap into the speakers/amp/antenna/etc.
All of the above are assumptions on my end obviously but I don't see why it would not be possible.
I bought a salvaged dash and I am going to fabricate a double din faceplate that looks like factory. Once I have everything out of the car I will see what room I have to play with. I have seen a few installs that looked REALLY good except for the orientation of the headunit(see below). Those sit low leaving this large space at the top which effects the stock look of the install. I think this is due to the CD player aspect of the hardware. The unit I will be using will be an Android unit with no CD and thus a much shallower hardware profile behind the dash which should allow me to place the unit in a more centered position.
I'm really excited to get into this project. As soon as the wife gives me the go ahead for the rest of the audio gear I'll post some progress shots
I'm old, so I guess the usefulness of HD vs. Non-HD are lost on me. I don't really look at the display much unless I'm using Nav.. which I can see a benefit of HD on. The stock screen is 7" if I'm not mistaken, so not sure how much more 2" really gives you.. I know.. "That's what she said"..
Has anyone looked at what it would take to put a 2018 unit into the older units? Seems like it ticks the boxes and is from the factory, so integration should be easierish?
That second video showed quite a bit more of the install, and that just looks like a giant PITA. :)
Stereo
The fact it would be HD merely means a clearer image and more representative of the class of vehicle. The Nav looks like it was built in 1995 and that touchpad phone thing below the screen is laughably outdated even for 1995. The larger screen is necessary to fill the void space left from removing the NIT (ugly phone looking thing, actually part of the telematics of the car). Plus the larger screen aides in the more contemporary look
I did, the retro kit includes the screen and new dash/console pics and is close to $6k as I recall...FOOLISHNESS!
Yes its quite the undertaking but if the end result can improve the aesthetics and the lousy sound I'm definitely up for the challenge.
6K!? F that!!! Now I can see why it would make sense. Checking a little more, the other add-ons the OP mentioned (Steering wheel module) aren't necessary, so it's fairly on par with the NaviPlus price wise. My kids would dig being able to watch YouTube in HD on it, so it may be on my mod list whenever I finally get my damn GT..
I installed the Naviplus system in my GT several months ago and posted a whole thread about it back then. Essentially, there's a few pro's and a few cons.
The pro's are that you keep the OEM look of the infotainment unit (if you like the stock look), the OEM screen becomes a touch screen, and of course, you have Apple Carplay/Andriod Auto with all their benefits and functionality. (I particularly like the fact that I can pull up Google Maps and live traffic updates right there on the screen whenever I want to). It also comes with a nice back-up camera. The graphics in AppleCar Play mode is also higher res than the OEM "Atari 2600" graphics.
The con's are many and could be a deal breaker for some. The biggest is the installation which was a nightmare, even though I used a professional installer. The included instructions were incomplete and terrible. Lots of trial and error to get everything working. Tech support was also a nightmare because the company is in Australia. So I had to call them late at night just to speak to a live tech. Even after the system was installed, there are times when the unit would randomly stop working or the touchscreen stopped working. I have doubts about the long-term reliability of the system going forward.
After some further research, I stand corrected. The Alpine Halo9 unit is a WVGA screen (i.e. 480p) so not a true HD screen. Disappointing!
Alpine came out with another Halo9 model this year (iLX-F259) but surprisingly the goal was to make this year's unit cheaper to attract more interest. They did this by keeping the screen resolution the same and removing some features. Again, disappointing.
Maybe I'll have to keep my plans on hold and hope Alpine decides to give the Halo9 line a proper screen or someone else makes a single DIN system.
Until then, I'll keep watching this thread to see what Franz comes up with.
Just a note - by using the Alpine you'll lose the ability to do things like reset your trip odometer.
Another note - some Alpine systems support wireless CarPlay but I think the Halo and also the Navistar unit do not (need to plug in the phone).
I have heard mixed reviews of the Navi and Carplay interfaces but aside from their benefits/shortcomings it still doesn't eliminate the biggest eyesore of the whole car, the f-ing horrible phone keypad. I will HAVE to retain that stupid phone NIT so I don't have interface issues with the trip meter/odometer/clock and all the other BS that Maserati has tied into that thing. I will just have it relocated and hidden in the trunk or something. Despite the difficulties, I am really looking forward to the chance to improve the one thing I HATE about the car. If I had the money to just buy the retrofit from Maserati I would, but I cant justify THAT much money.
Yeh, the Halo9 does not support wireless CarPlay or AndroidAuto. Outside of OEM integration, I think Kenwood and Pioneer may be the only ones that offer aftermarket head units with that feature. I would obviously prefer to have the wireless option to truly have a seamless experience worthy of the year 2019.
Also, the trip reset can still be done by holding the Mode button for 2seconds when viewing Trip A or Trip B. But on a deeper note, I didn't think removing the radio would remove any other functionality. I thought the single DIN radio was just that...a radio. My understanding was that removing the NIT is what would sacrifice some OEM functions so as long as the NIT stays, all is good.
If someone can shed light on this, would be much appreciated!
My understanding from prior threads is that the NIT also controls the clock and removing will also cause the odometer to flash constantly.
The NIT *is* the radio. Single Din unit all in one.
Which bit do you think is the NIT?
Removal will I suspect cause some other issues for the car's system as it's expected to be there.
I'll be damned...I dug deeper into this topic and you are correct! I had incorrectly assumed that the "brains" were behind the display and the radio was just a radio but it IS the NIT.
Well...that's good to know but also disappointing. I guess I'll have to consider relocating that to either the trunk or the glovebox...whatever is easier to route.
I contacted the two companies that did the Alpine install to get feedback on how they handled the NIT so let's see what they come back with.
By the way, I found the below post from another thread to be very helpful. It's a Maserati document that lays out the various components/functions of the car and how they integrate with the NIT.
not a pinout, per se, but a lot of good info:
Advanced Electronics 3 - Comfort on Scribd. Check it out: https://www.scribd.com/book/201140059
if you don't have scribd (which I hate) I hacked their site to download the pdfs. don't have those handy on my phone though.
I have the PDF. It's simple to get a harness adapter for the audio functions of the NIT. There are video and data connections as well.
1 - 20 of 85 Posts
