1 - 3 of 3 Posts
I’m day 3 into owning my first Maserati! To say I’m excited is an understatement. I just bought a 2013 GranTurismo Sport. My problem is hopefully a simple fix. The AUX input works perfectly, but the full function USB does nothing. In addition, USB, CD, Jukebox are all grayed out under the audio functions. Any suggestions?
They are greyed out until something is there to switch to. Put in a CD and the CD selection should be there. (If not, then you do have a problem.)
Ha, finding a CD was the tricky part. But you were right, putting a CD in did illuminate the CD option. Thank you. I still have a "dead" USB port however. I have read other posts, where people mention a bad fuse. What fuse is it? I don't see it clearly labeled in the manual. I've also seen people say it doesn't work with iPhones, but rather older iPods and Android phones. That doesn't seem like it should be the case.
1 - 3 of 3 Posts
