I really love the head unit - works great and sounds significantly better than the stock head unit. HUGE difference in audio quality.
Some questions I have:
1. Some sounds do not play under CarPlay. For example open Messages under CarPlay and tap on a message. It's supposed to read the message but I get silence. Same if I use Siri. Can someone else confirm?
2. WiFi is off by default - I always have to manually turn it on.
3. The car has 2 Bluetooth chips, one for audio streaming etc and one for data such as OBDII and TPMS sensors. The second one, which you can access under Bluetooth->Settings->Bluetooth Data is always off and I need to manually turn it on. Any way to have it on by default so I can use my OBDII app without having to manually turn it on each time? Here's the menu:
Tip:
OBDII is amazing! I got one of these https://www.amazon.com/Bluetooth-Sc...hild=1&keywords=elm327&qid=1622375146&sr=8-14
And now I can display these info:
Tip:
