1 - 2 of 2 Posts
I am trying to find aftermarket wheels. Does anyone know the wheel spec for the 02 coupe? I would like to know the factory spec offset, bolt pattern, and the center bore.
Do the QP wheels have the same offset as the Coupe? Do they fit the coupe?
For you guys that have aftermarket wheels, do you keep the same offset?
Thanks,
Pganmol
I have aftermarket 19inch rims, here are the specs, I have had no issues. Also, the rim fittiment were specifically for the Spyder (the coupe is the same)
Front 19x 8 62.2 MM Offset
rear---19 x 9.5 55.5 MM offset
5 x108
Stock is
18 x 8 ---63.7 mm
18.9.5 ----55.5 mm
1 - 2 of 2 Posts
