You may be able to fix it yourself...
Regardless, an independant should be able to.
Actuator -> heater cock actuator that is, NOT the panel controls. When the E fires, that signals the actuator got jammed. So you want heat... none, as the controls are unresponsive. Ditto for A/C.
Trying to find on the Eurospares site where the heck it is...
Part # 12 or 13 here maybe..?Well - I have to say - listen to the expert ! Looks like it is this bit (heater cock/actuator jobby that's now ripe for investigation.![]()
Had a good browse through the Eurospares site and can't see it anywhere - did you ever find it ?
Cheers
CJ
Was looking at those bits but wasn't sure if they were the right ones.Part # 12 or 13 here maybe..?
http://www.eurospares.co.uk/partTable.asp?M=3&Mo=384&A=2&B=20557&S=
which I guess by looking at this one
http://www.eurospares.co.uk/partTable.asp?M=3&Mo=384&A=2&B=20517&S=
and knowing how to access the air pollen filter by removing part # 1 here
http://www.eurospares.co.uk/partTable.asp?M=3&Mo=384&A=2&B=20546&S=
suggests, maybe, thay you can only access the sucker from inside. Price for the part also matches what I was quoted (40 quid).
But then, I'm not Joe Mechanic![]()
My ecode has decided not to come on for a few days now, it must realise I'm watching it ! Will check out the tip and see what comes up next time it decides to do it. May be worth everyone posting their codes and results ?hi
if you have the letter e on your display then you can check the code just by pressing the two buttons your heater panel. if you hold them for a couple of second the display will say AA and then come up with a number.
you need to note the number down.
Once you have the number you can contact your maserati dealer or specialist and they will be able to find the fault quickly.
Simple little tip
I hope it helps
It's the recirc and econ buttons on the heater control panel !what are they labeled? I do not see any heat buttons; just alot of info centre radio crap!!!!!!!!!!
