1 - 11 of 11 Posts
Anyone else have this pop up when on here? Little research pointing to issue on websites’s publishers side.
Administrator
There is some exploit with IOS and certain sites, that's allowing those popups into your browser. We're looking into it, but for now we are putting specific blocks into place to at least alleviate the symptoms.
Next time you get one, if you can grab the full URL in the address bar when this happens, we can use that to track and block
Kevin
Administrator
Hey there,
One solution is to use enhanced mobile view (not available on IPads/only vBulletin sites) or use tapatalk.
Another is to turn off javascript if you're using safari, but this will make some functions not work. Settings > Safari > Advanced > Turn off Javascript
An apple user reported that they turned it off for a while and turned javascript back on and the pop-ups came up less.
Maybe give this a try and see how this goes?
I will report those ads you have linked, thanks
Ed
1 - 11 of 11 Posts
