my front alignment is a little too cambererd in and has a touch too much toe in which is causing about a 3" fast wear patch on the inner edge of the tire what alignment specs are you all running and does anyone else have this issue?
This is a common issue. Stock alignment has a lot of negative camber at front, I still got 18,000 out of my fronts.
I don't have alignment specs.
i got my 90th anniversary spyder done a month ago and here are the results and specs:
Front: Left
Actual Specified Range
-0°30' -0°36' -0°24' Camber
3°33' 3°31' 3°43' Caster
-2.0mm -2.3mm -1.8mm Toe
Front: Right
-0°33' -0°36' -0°24' Camber
3°47' 3°36' 3°48' Caster
Front:
0°03' Cross Camber
-0°14' Cross Caster
-4.0mm -4.5.3mm -3.5mm Total Toe
Rear: Left
-1°39' -1°48' -1°36' Camber
2.0mm 1.8mm 2.3mm Toe
Rear: Right
-1°36' -1°48' -1°36' Camber
Rear:
4.0mm 3.5mm 4.5mm Total Toe
0.00° Thrust Angle
fronts had about 5k on them and they were shot hence my need to get this thing tweaked...oh well I think I will get it lowered first then start tweaking the alignment...is this car a turnbuckle system (threaded) or a standard shim setup?
