1 - 9 of 9 Posts
Hi all,
My airbag warning light is constantly on and I was wondering if anyone here has faced a similar problem? I took my car to an Indy and he couldn't figure out what the issue was as there was no error code coming up.
Thank you
I had a similar issue last year. It turned out to be that one of my airbags (drivers side door) was bad. They replaced it and all good now. I believe the only way you can get detail on the airbag warning light is with the Maserati/Ferrari specific SD3 tool at the dealership.
Good luck!
The other known issue is the switch for disabling the passenger airbag. It's a Fiat / Alfa part and much cheaper if bought from them.
Dead easy to change as well, apparently.
Reactions: Andrew224
I had this on my QP. In my case it turned out to be a bad contact on a side airbag which was cleaned up and she was good to go.
This is a safety issue and I would not leave it too long or try to bypass the working of the airbag. Please get it taken care of ASAP and keep safe!
:cheers:
Good luck!
The Indy plugged in the SD3 and said no error code came up so said it could be the actual computer component that needs changing and said that I should take it to the dealer but I'm away now so won't be able to do anything about it now. Does anyone have an approximate cost of replacing a component ?
Plus my car is up for sale so just wanted to ensure that I can sort it out before giving her away!
I'm sure when you take to the dealership, they will be able read the error code. I believe I paid about $425 (Canadian) for the passenger air bag, + an hour labour? I would see what the dealership wants then compare it to Eurospares. The European prices are almost always less expensive than here in North America (http://www.eurospares.co.uk/index.asp?M=3&Mo=383&A=2&G=&S= )
Good luck!:thumbsup:
Does the Gransport have one of these ? My car only has a hole and no switch.......Maybe that is why my airbag light is also on ?
oops. just checked the eurospares site....the north american cars do not have the switch...at least, not the gransport.
Paul
I had my Granturismo airbag on, after search forum chat n Google - note that there is a sensor under the passenger n harness wiring to the safety belt. After shifting the passenger backward n retrieve out the harness underside. Discovered one the the thin yellow wire was rapture n exposed possibly touch the metal body of the car frame causing a short circuit. Leading to warning light n indicate airbag failure refer to dealer.
after taping up the exposed wire n restart the car, the warning light is gone n not appear anymore.. problem addressed. The wire was probably pinned or wear off due to the seat adjustments. I also insulated the harness with cloth tapes properly tie them together with cable tie to better manage them n stuff back under the seat securely to prevent future damage n wear off again. Share to all to check this possible fault n a very simple fix.
1 - 9 of 9 Posts
