I decided to change the air filter on my 2004 Coupe and I wanted to share some tips based on my experience.
I replaced the filter with a Maserati filter. Old filter (black one) did not look too bad and I knew it was replaced a few years ago but I figured it would not hurt to put a new one in.
The filter is located in a housing forward of the front left tire. To access it, the front left tire and the wheel arch lining have to come off (wheel arch lining is two sections, only the front one needs to come off).
The housing cover is held in place by four fasteners visible in the image below and two clips on the side (see next image). Once the fasteners are loose, unclip the sides and pull down and aft. The front has straight tabs.
Clips (one per side)
Front part showing the three straight tabs.
I have read about a user complaining that the Maserati filter would not fit well. It was indeed tricky to push it it in and I had to remove the front bumper bottom lip to have enough leverage to push the new filter in securely. Perhaps it can be done without removing the bumper lip but after getting frustrated I decided to take it off (it is just a bunch of 10mm bolts) and then it was easy to push the new filter in from the bottom.
Not an exciting topic but wanted to get it documented for fellow owners.
