Hi all,
First technical post for me: thanks for having me and right off the batt I wanted to say thanks to everyone for all the useful and humours posts, its been fun lurking an learning for a while.
At the beginning of this year I bought my first Maserati, a 2004 CC and love it, it has various annoyances and funnies but in general its great. This weekend however the ball joint on the front left-hand lower wishbone (control arm?) failed catastrophically and left me stranded (literally as the AA couldn't or wouldn't recover me).
Fool on me for not checking the ball joint condition. Now I have sourced a replacement wishbone from eurospares and am embarking on the replacement before I thoroughly check all the other ball joints, bushes and potential cracked arms. And here is where I'd like a little help.
The first issue I'm having is that it seems that one of the wishbone bolts is obstructed by my steering control arm, so I cant easily extract it:
Is that normal? Is the bolt normally fed in from the other side? When you guys have swapped wishbones have you had to remove the control arm?
The second issue is that one of the 5mm Allen head bolts which hold on the suspension sensor seems to be obstructed by the hub, making me think I need to make a special short headed Allen key to get to it:
When i compare my image to one in the spring install manual I wonder if my bracket has had a knock, as this image seems to show easy access:
Any help gratefully received, and I'll keep you posted on progress.
Cheers,
Mike
Cheers,
Mike
