Hi,
A newbie to the forum - I've had a quick look around but couldn't see anything relevant - maybe you guys can shed some light?
I went to see a 2003 4200 manual coupe - everything seemed spot on apart from a rattle from underneath the car - directly below the gearstick - it went away with dipping the clutch - just a loose linkage?
After a spirited test drive it started to leak warm water from roughly the same place. It could be condenser water heated by dripping off of the exhaust - then again a buggered matrix though this should be in the car? It was completley clear and no smell to it.
Should I be worried? The car currently has a 3rd party warranty - added by a Maserati dealer.
I'm based in the UK.
Thanks!
Thanks!
