1 - 1 of 1 Posts
2005 Coupe CC
OK, here is part 2
m) now loop the belt around the alternator and under the idler pulley. Again, nudging the belt between the pulleys and the hard lines. Don't use screwdrivers or sticks or anything pointy. It fits, just have faith.
Tire Wheel Automotive tire Automotive lighting Tread
n) go under the car, cut the tie wrap and release the tension on the serpentine belt tool handle slowly
o) verify the belt is properly seated in the pulleys for the crank, the alternator, the power steering pump, and the a/c compressor
Hood Automotive lighting Motor vehicle Automotive design Grille
Automotive tire Hood Motor vehicle Automotive design Bumper
p) remove the serpentine belt tool
q) start the car and verify all is working well
r) use your Torx set to re-install the electrical bracket under the car
s) replace your rubberized plastic dust shield under the car
t) remove the jack stand and restore the car to the ground
Enjoy your car!!!
  • Helpful
Reactions: Oishi
1 - 1 of 1 Posts
