1 - 7 of 7 Posts
Hello, I recently found out that my license plate lights are not working. Does anyone know where the fuse is for them? Thanks!
There is a fusebox in the passenger compartment and one next to the battery in the trunk...Be just quickest to just check all of them with a test light real quick....Jason
When mine stopped working I noticed the receptacle, where you insert the bulb, was not tightly holding the bulb. I bent inward the tabs on each end and that ended my problem. Good luck.
Discussion Starter #5 (Edited)
UPDATE:
I did some dignosing and the light bults are in working condition. And the bulbs have strong contact to the tabs. But there’s no power going through (there’s no power coming through the wires). The fuses in the trunk all looked fine and gets 12 volts.
By the way, it's Granturismo.
1 - 7 of 7 Posts
