1 - 2 of 2 Posts
i think you must remove rear door panel.
1 - Disconnect battery (negative)
2 - Remove the lower sap fitted moulding
3 - remove the snap fited door handle cover
4 - remove the retroflector
5 - remove the snap fitted floor lighting lamp and detach the connector
6 - remove the screw rubber cover located behind the handle
7 - undo 2 screws fastening the door panel
8 - undo the door panel fastening screw
And
diconnect the bowden cable for the door opening control and the door wiring connector
1 - 2 of 2 Posts
