Hello I just bought this vehicle in a auction and it won't start. It cranks but will not start. On the dash its saying engine oil pressure sensor failure. And the oil line is leaking pretty bad on the bottom of the car. Would that be why its not starting? Thanks in advance...
You can do it. I bought mine site unseen and not running. Theses aren't as complex as many make them out to be. Find out where the oil leaks coming from, fix that. Then replace that oil pressure sensor. I imagine the PCM won't allow it to start with that bad. It assumes zero oil pressure and keeps fro starting to save itself.
