I have a 2005 Quattroporte and the wipers are not working.
I have tested the wiper motor and it works.
I can spray water on the hood with the headlight cleaner although it doesn't spray water on the windshield.
I have replaced the Wiper control module with a new one based on my VIN from the Maserati parts website.
I have taken the column shroud off and checked the connections and the switch appears to be in good condition.
I have replaced all the fuses related to the wipers
Just wondering if anyone has anymore suggestions?
2005 Maserati Quattroporte
I know this is an old thread, on my '05 QP washer doesn't spray on the windshield, Wipers and Headlamp Washers work, i replaced the control module like you and still not working. I even swapped connectors between headlamp washer pump and windshield washer pump, and the pump works. When I check continuity, the Windshield Washer Relay gets a very dimmed signal when wiper lever pulled. Have you fixed it on your car??
