What he said. But the light code needs to be reset. I replaced a side marker bulb and warning still comes up.For starters, the "low trans oil" light on a F1 car like yours won't go out with a OBD reset. Once the oil is up to spec, then it'll go out.
Have you checked the F1 fluid level?
The headlight failure warning has nothing to do with the sidemarkers...Two totally different systems...The system doesn't need to be cleared for a simple sidemarker out...JasonWhat he said. But the light code needs to be reset. I replaced a side marker bulb and warning still comes up.
I never said the headlight warning was related to the sidemark. All i said was i had a warning and replaced a side marker blub as that was the one out and the system still has the warning coming up. That was the only blub that was out. Maybe last owner had another blub out and didn't clear the code.The headlight failure warning has nothing to do with the sidemarkers...Two totally different systems...The system doesn't need to be cleared for a simple sidemarker out...Jason
Do not know. car is new to me and learning about it and going to use it for a project when I get sometime. Plus do not have a scan tool.What code? You just restart the car to clear the warning...J
