Looking for some input on several problems which my Dec04 Coupe with 10 k miles has gotten over the last 10 days:
1) Aircon leak (or so I suspect) large quantity of fluid escaped into the interior of the car (passenger side) on 3 separate occasions over 2 days. Seems to have stopped now, I soaked it all up with newspapers so thankfully no bad smells have developped
2) Airflow direction/mode switch (the middle big dial on the center console) is stuck (not physically) on Max Defrost. I tried switching the car off and on, disconnected the main battery switch for 10 mins, etc. but no matter what position I put it in, it remains in Max Defrost function
3) Vibrations: (most felt in steering wheel and outer pilars) Start at 100 mph, worst at 110 mph disappear again over 120 mph, worst on ultra smooth road surface. Dealer says it is most likely tyres, which would not surprise me either, but they do not look excessively worn, even on the inner ends. Could this really only be tyres? The car did not do this before, then again I dont drive at those speeds on a regular basis...
4) My cambiocorsa light on the dashboard came on for a few seconds while slowing down in 2nd gear the car beeped 3 times, I immediately put it in Neutral and then back in gear, which worked wihout any noticable problems, light remained on for another 20 secs or so and went off again. Has not reoccured since, but I've not made more than 50 miles since.
It goes to the shop on August 7, so any suggestions on what I should insist on being done/checked are appreciated, especially since my waranty is only good for a few more months.
