Interesting question, it caused me to think back over the past couple of years and I realized that the Maserati Spyder has really been reliable with no major problems and only a few things that I had to get used to.
My 03 spyder runs a little rough for the first 1 to 2 minutes. The check engine light can come on if you give it too much gas during the first minute. I'm a firm believer of babying the car until it warms up so this isn't an issue for me. Having the check engine light come on has happened twice while I've had the car. The first time the dealer checked everything out. The second time it turned itself off before I could get it back to the dealer.
The F1 transmission is what it is. The only two times that I wish I had a stick is for stopping and starting on steep hills and stop and go traffic. The transmission works in both cases but I think a driver has a little more control with a foot clutch instead of using the throttle to engage the clutch. In general the F1 transmission is a fun toy and works well. I'm in the minority I know, but I even find the automatic mode to work well.
I've had the top refuse to complete an up / down movement a couple of times. In both cases simply turning the car off and back on made everything fine again. The only time this was an issue is when I was putting the top down while waiting at a red light (yes there is enough time if you start it just after the light turns red - your mileage may vary depending on the duration of lights in your area).
Overall the Maserati Spyder has been a great car and I've enjoyed it.
Good luck.
Good luck.
