Dear Friends, I have a 2002 spyder GT with a six speed trans... Sometimes when I go to put it into gear it won't go in. The same in all foreward gears and revierse. I have changed the clutch master cyc. twice I have check all lines for leaks( no leaks found) no drips on floor I can't see anything. I have bleed the system. I drove the car for maybe two hundred miles one day sifting many times during that trip no problem. Then put the car away in the garage a couple of weeks went by I went to use the car and a I can't get it into gear again the same proplem again. I changed the master brake cyc again and it did it again. There is no noise from the clutch the car has only nine thousand miles on it. I am afraid to use and wind up stuck somewhere. Does anyone have any Idea what I should do about it. It is driving me crazy PLEASE HELP Also I would like to mention that the clutch peddle loses it's pressure and once I kept pumping it and the pressure came back up.The rest of the time I can't get the pressure to return to the peddle.
