1 - 20 of 53 Posts
Hello all, I just got my Major service kit put together, Not pictured is the cabin filter, its being shipped, for only $500. I have a 2013 GTS that I purchased with only 11,216 miles in April of 2019, I now have 15,044 miles on the clock. I have no idea when the last service was except for when I got the car with 11,216 miles, the first thing I did was order the oil change kit from FD. The belts are now 7 years old so it will be a great piece of mind. I would assume the brake fluid has never been changed either.
As you will see this kits contains OEM Maserati oil, Q horsepower 5w-40, OEM oil filter w/ new crush washer, Power steering fluid, Motul brake fluid, Concentrate Coolant, Serpentine belt, Acc Belt, BMC Air filter, and Cabin Air filter (not pictured).
I will be doing a Major Service video within the next couple months to show how you can do it yourself at home, I will also have a list of tools needed which is pretty basic.
I did invest in a very nice scanner (Autel MX808) for about $350 that I reset the green wrench light when I changed the oil for the first time myself, You can use this scanner on ANY car. I also invested in a Motive Power Bleeder for $85. Works on most German cars as well.
Stay tuned!
Robin, looking forward to the DIY video and discussion for this job. My car won't be needing this for a good while, but I'll definitely be doing it myself when it is needed so this will be a great reference.
Stay tuned!
Love my Motive bleeder, well built and works wonderfully well (y)
Doing some similar maintenance as I already did the oil change. Super easy except for the stuck oil filter (came off with the right oil filter wrench). I ordered the 2 belts as I believe the maintenance schedule for them to be changed every 2 years. I'll probably do that in a few weeks. Looking forward to some more DIY info on the forum to save money on these maintenance costs whenever possible. I (usually) enjoy doing the work myself because I like learning about the car and get a feeling of accomplishment.
I am really looking forward to this too. That brake bleeder looks really interesting, I had never heard of that before - boy would that be a time saver!
I see you bought a Motive Brake Kit, so did I, I also bought a brake fluid tester (less than $10 on Amazon). Guess what, the Mas tested good but my Audi (dealer maintained) tested way bad. So no loss, I changed the Audi fluid an will keep testing the Mas. When it shows less than good, I’ll change it.
Grab you one of these puppies, shout out to forum member tulit for this hook up... $10
86mm 18 Flutes Silver Tone Metal Car Oil Filter Cap
www.newegg.com
Discussion Starter #11
Good work! Not to parse words, but that's a fluid service, not really a "major service". None the less, I love when guys get their hands dirty. Better bonding experience with the car. :)
Yep I agree but that's Maserati major service. I see why you have to change the belts more often....they are very small.
This might help.
I have planned the same maintenance, also doing spark plugs and diff oil next time.I will still let my specialist check the car over once a year and reset some stuff. Since they really know what to look for and check and for a piece of mind.
But all the basic maintenance doesnt seem any harder then a regular toyota.
Major service, or minor service, a top notch independent mechanic shop should be able to do most anything the dealer would, for at least 30% less and often even less than that, depending on the service. I say "most anything" because there are a few things which probably can't be done without the use of the dealers' computers, but I imagine for any preventive maintenance and basic service, most repairs , out of warranty , there is no reason to take the car to a dealer. IMO. But if you're a DIY-er, even more savings to be had (y) . I'm not, so that's why I rely on others, although if I lived in an area where only dealers were available, I'd be compelled to start doing basic things on my own pretty quickly, I hate throwing money at dealers unnecessarily ..
This might help.
I did this last year although I did a full brake and rotor swap, but didn't get to bleeding the fluid.That's this year, plus differential fluid change.
The only problem I had was dealing with stripped screws on the covers underneath the engine.
Don’t forget the differential, My car’s records show regular maintenance but I don’t think the differential oil was ever changed.
1 - 20 of 53 Posts
