1 - 16 of 16 Posts
2006 Gransport LE
Not here either - and although I'll check again, don't seem to recall it during my various persuls through the manual or the Maserati repair manual - but will look again since I could use a small adjustment.
unfortunately I don't have the little wheel either?? I have a 6M Coupe, maybe it did come with electronic adjustment?
I haven't done it but I saw in this forum that the adjustments are accessed by removing the forward section of the wheel well liner. Not really meant to be adjusted after assembly. That's for the xenon lights, as I understood it.
If you have no "wheel" on the dash then you should have xenon lights fitted. They have automatic adjustment for ride-height. These are not, as far as I know, adjustable by hand - if they are out of alignment a dealer visit may be in order.
If you really want to take alook the headlights can be removed by disassembling the surrounding panels including the one inside the wheel arch. and unbolting the headlight assembly. There was another recent post describing this procedure.
http://www.maseratilife.com/forums/showthread.php?t=4771
Off topic.
Barbuckle, is your GS a 2007? I thought the last year was 2006. Did you guys in Europe get another year of production?
The year on my signature is the first registration for use as a new car in the UK (June 2007).
As to the production date - hard to say. But I remember being unable to visit the Maserati factory at end of 2006 as they were re-tooling the line for GT production to commence so I guess the last production GS's were late 2006 or early 2007 at latest?
1 - 16 of 16 Posts
