2009 GTS F1 does not shift out of 2 gear either manually or auto mode. The F1 fault indicator comes up on dash.
Had Maserati look up code it was a low voltage code. Car drove great after reset then after car is turned off it does the same thing. This time Maserati could not reset code, it became permanent. Its at Maserati to get checked by the F1 expert. Anyone had this issue? Reading some of the threads looks a lot like the cable issue. Clutch life remaining is 65%. 34k Miles.
