I noticed the main display screen on my 04 Spyder is suddenly very dim. It is not becuase of the "main dark" setting - just a lit dimmer than usual (can't read it with sunglasses for example). Is there a setting to bring the brightness up?
+1 on this! I bought a new pair of Maui Jim's, and its amazing! It almost blocks out the entire screen! At first I thought my unit was going bad! I pulled of my sunglasses to take a closer look and it was absolutely normal... but them on again, and it was like someone turned down the brightness by a factor of 10!You didn't happen to be wearing a new pair of sunglasses, did you? I've noticed that when I wear my polarized shades, the NIT screen is almost invisible.
The only brightness setting I've seen is for the nighttime dimmer, under one of the Main Screen menus.
