1 - 3 of 3 Posts
dutchlincoln
Hello,
I own a Maserati Quattroporte 2007 since a few weeks.
When i bought the car, it was fine.
Right now, i have some gremlins...
When i lock the car with the remote, the red light at the doors blink, car locked. When i unlock the car with the remote, green led blinks, and then goes off. When i ope the door, the alarm sounds. In the display of the odometer the alarm gives a malfuction. Alarm goes off 30 sec, stops, again 30 sec, stops, and again 30 sec, then silence, but blinkers still blinking. (batteries in the remote are changed for new ones.)
(Remote works fine; when i keep unlock pressed, windows all go down, when i keep lock pressed, windows go up.)
When i lock/unlock the car with the key, be it driver or passenger side, everything is just fine.
Also, in the odometer sometimes the seat heating is displaying, giving an erratic 0 and 1, like its being switched on and off contantly. (where can i switch it on and off?)
Last; i need the radio code, but the code i got from the maserati dealer, corresponding to Vin number, doesnt work.
Anyone?
Welcome to the world of Italian electrics! problems! All those symptoms don’t have any common cause that I know of, other than a battery needing replacement. You will still need the code, and that may require a trip to the dealer if their lookup by VIN didn’t work.
Give it a shot and keep us posted!
Needs a proper scan to look at that alarm I suspect. Although you can try arming it with the door open
Ref the seat heating: Likely cause is water running from the roof into the controls on the seat. Sometimes they can be cleaned, otherwise replacement is probably the fix
1 - 3 of 3 Posts
